so the dyno was done, 277rwkw, 40psi, blown head gasket
What is the torque?
He doesn't like giving out what he used let alone dyno specs hahaThat is impressive as s***. EDIT: Do you have a video of the gauges during that pull? I'm curious at what RPM the boost comes up.
Can you post up which intercooler that is, or what the dimensions are?
935nmWhat is the torque?
we melted the pistons out of one car but it was a bolt it on and see what happens s kind of deal with no worry about consequences. Car was very fast for a couple thousand miles and then it got really slow.Thanks guys,
Seth, if the pistons melt and run out the sump plug, I'll send em to ya! Make a great talking piece for all you talkers.
A good article on keeping the pressure in the cylinder
Boost Is King, But Can Your Head Gaskets Handle It?
The key to containing large amounts of boost within an engine comes down to two things--proper preparation and adequate cylinder seal.www.enginelabs.com
ThaA good article on keeping the pressure in the cylinder
Thanks Seth that's a bloody ripper article, Its more directed towards bulk boost and racing preparations, but boost is boost, as the chart states 4.6 psi is around 134kpa pressure....A good article on keeping the pressure in the cylinder
