trip odometer and ODO not working on 100 series
Venezuela
my 07 100 series trip odo is not showing , I can feel the button clicking but is not showing, the other problem related to it is the total odo is showing but mileage ( KM on my case) is not calculating while Im driving , only when switch ignition on and off the numbers add up! Ive looked everywhere to find a solution but no luck , Ive taken down the dash to see if theres something wrong and also no luck! HELP please
Check your speed sensor at the transfer case before trying the cluster. Tanin will charge you $700 for the full rebuild (they only do full rebuilds, no isolated repairs). You could theoretically replace every speed sensor on the truck before approaching the cost of a cluster rebuild.
Tanin just did my cluster this summer. I had a few inoperable gauges, but my odometer never faulted unless the speed sensor was unplugged.
Hey , thanks , the speed sensor is working so is everything else , the mileage is showing but is not being calculated when driving , just when stop and switch ignition again , the trip ODO is also not showing those are the issue but i can see my speed
