Help!! Transmission overheating problem has me stumped
1KZ-te with a340f tranny. External tans cooler in series with the radiator (radiator first, cooler second). Temp probe in the flex hose connecting the transmission outlet pipe to the rad inlet.
When I am driving on the highway under load (100-120kmh), tranny temp is around 150F. As soon as I start coasting or slowing down with my foot off the gas, it spikes to 210-250F. Wtf?
I initially thought that the problem was engine cooling, so replaced fan clutch oil with 10,000 cst. However, stand-alone coolant temp gauge shows a consistent 190-210F and there is no connection at all between the engine temp and tranny temp spikes (coolant temp probe is in the radiator outlet hose - top left corner of the rad).
I use synthetic ATF and it’s at the right “hot” level.
What am I missing here? If the problem was the rad core, wouldn’t I see engine temp problems?
