- Joined
- Jan 28, 2010
- Threads
- 7
- Messages
- 23
1999 LC 199k miles. Just had 90k service done including transmission, differentials, transfer case service. Had bearings and brakes less than a year ago and probably only 5-6 k miles ago.
Headed down the hwy today pulled over on the side of the road to see if a store was open, went to pull away and the LC won't go and there is a terrible noise coming from under the car. Tried it again and managed to drive one block to a gas station. It did the same for just a second then worked. Drove around a block and it did it once more. I put the trans shifter into neutral then shifted the transfer case hi to low a few times. Then I drove 60 hwy miles with no issue.
Had to slow down for a turn went less than a mile and the same thing happened. As I was coasting I shifted into N and can still hear the noise. Then I stopped and shifted into every gear stopped with my foot on the brake and in every gear it would make the noise.
So then I put the transmission in N shifted the transfer case to L, transmission to D and drove home 20 miles without incident other than only going 20 mph. And it seemed to shift fine. There are no warning lights or check engine lights on.
I'd really appreciate your possible diagnoses and suggestions. thanks.
