Transmission Oil Cooler options?
Sespe
Hello all-
I did a search, but no luck. Maybe someone here can help.
I need to replace my transmission oil cooler on my mostly stock, non-locked, '97 LC. Due to the aftermarket front bumper/winch combination (BellLabs bumper/Apex 1200 winch) I'm installing, I need a trany-cooler that is about 1 1/2" to 2" shorter. I can't install the Apex control box remotely because, with a second battery, I don't have the space.
I've already trimmed the center grill/latch support to tuck the winch in. And I've trimmed the trany-cooler brackets to move it up and driver side as much as possible. I'm still lacking a smidge of space.
The OEM cooler is 13"H x 10"W (not including brackets) x 1 3/4" deep. A cooler 10"- 11"H would be ideal. I can go a little wider. Any suggestion from the aftermarket or from other vehicle models? TIA
Look at trucool and see if there's a size that will work for you. I have one on my F350 and never see temps higher than 175F.
