I changed the oil and transmission fluid in my 1994 LC (193,000 miles). I have had the vehicle for a year now and it was the first time I changed the transmission fluid. I just pulled the trans. dipstick, removed the 24 mm drain plug and let it drain completely. I poured off and measured the old fluid (burnt sienna color - definitely needed changing) and calculated 6.2 quarts.
I have read that people get about 4 to 5 quarts out. I checked the dipstick before draining and it showed the correct level.
I put 6.2 quarts back in (Dex III ATF) and the dipstick shows the correct amount.
Does this sound a little high? I will keep checking it the make sure I was not getting an incorrect reading (flat surface/Hot & Cold engine).
Thanks,
Riley
Thanks,
Riley
