transmission filter part number
Houston, TX
I plan to replace the transmission fluid and filter. I'm coming up with two part numbers for the filter: 35330-60060 and 35330-60070. There is a $15 price difference between the two. Any idea which one is correct? I have a 2015 LX 570.
Also, can the pan gasket be reused or does it need to be replaced? Thanks.
From what I understand, that is a screen and not a filter and doesn't "need" to be replaced when changing fluid.
Replace the pan gasket if you choose to drop the pan. It won't survive the ordeal it is to get the pan to separate from the tranny. In hindsight I would have left the pan alone. The mesh screen was clean even at 100k.
