I’m looking at purchasing a Pop-up trailer that weighs about 3500lbs loaded. Will my ’98 LC pull it ok? Anyone done this with there’s?
DMX84 said:Are the 100’s equipped with adequate transmission coolers? And what about the overdrive, will it be ok to use if it does not have to shift in and out allot? Like on level ground?
Thanks
DMX
tabraha said:Yes, in my experience the tranny cooler is plenty adequate. I've towed a good bit more than 3500lbs a few times with elev. changes without issue. Your o/d will be fine too on flat land.
Tad
sleeoffroad said:Last year I towed the ShortBus to Moab with my 100 and ben towed his truck with a Tundra. Although the Shortbus was probably about 2k lbs more, I could run with him on the straights, but he lost me on the hills. However the leaf spring setup in the Tundra made the towing much safer and more controlled.
Even with a weight distributing hitch, the towing sucked with the 100 and right after that I bought a big truck to tow with. Granted, it was more than 3k lbs I was towing, but the coil spring back end does funny things when a trailer starts to push it in corners.
