life insurance premium up to date?
beno said:Mods: Can we link this as a FAQ. We have a very good discussion along with part numbers (always worth bookmarking) from King o Parts.![]()
cruiserdan said:This almost always happens some time after a knuckle job. When the steering arms are removed as part of the repair the studs back out just a bit. The axle is re-assembled without checking to make sure the studs are tight. Even correctly torqued nuts will not prevent the studs from backing out if they are not secure.
otis22 said:i just repacked my BIRFs about 2 weeks ago and don't recollect whether the studs were tight or not. Is there any accurate method for checking whether the studs are tight, once everything is assembled? My guess would be to periodically check the torque setting on the nuts for the next few weeks to see if they change and to look for signs of leakage or gaps are beginning to form. Do the torque settings normally change on the nuts after the repack from driving the vehicle the first time or are they fairly stable once they are set?
Riad said:Curran,
Looks to me that the studs are attached to the knuckle? Can they be parmanently attached to the knuckle?
