They don't make em like they used to.
Just bought this nice little 1951 Allis Chalmers HD7 dozer. 4-71 Detroit Diesel, 10’ adjustable blade and double winches on the rear. We’re going to use it to clear some land on our place and plow our driveway.
I was looking at getting a quad with a snow plow or putting a plow on my truck or cruiser but for $4300 this was cheaper. And it runs like a top. The last owner had it for 16 years and put 100hrs on it.
Give me 20years unlimited free time and a free hand at the fuel pump and I’ll get there!In a former life, when I worked with the R.O. of Engineering for Invermere forest district, I oversaw a contractor who built and repaired roads using a dozer with a “5 way” blade. What the old guy could do with it would blow you away. He’d carve roads up the mountain side to fire lookouts, dig in water bars for drainage, and ditches along the side of the road all with the same blade.
One time I stopped by to inspect his work he commented he knew he’d got it right when he saw a BMW sedan on the way up to the fire lookout tower. There aren’t many left out there with that level of expertise who could do so much with only one dozer.
I think if I could go back I'd buy a slightly bigger tractor, and also get an offset flail mower instead of the under belly mower i have now. It's a little light when you get some heavy weight up frontNice. Those things are savage. I've been half assed looking for a flail or brush hog of some sort instead of just driving my old ride on into the 8' tall thorn bushes, but so far they've all been too far away or I'm too cheap...![]()
Yeah I think about stepping up pretty often. Mine is old and pretty haggard, but I can't complain, it was cheap and has been awesome for 5 yearsI think if I could go back I'd buy a slightly bigger tractor, and also get an offset flail mower instead of the under belly mower i have now. It's a little light when you get some heavy weight up front
I almost bought an offset flail but the tractor guys warned me they thought it might be too heavy and flip the tractor if I offset it too far. Their suggestion was to buy one of these instead for what I want to do.
I know that the sardine can Saginaw pumps have a regulator on the outlet for the high pressure outlet. If the hole is drilled out slightly larger the pump's flow can be increased and by adding shims increasing the pressure. By selecting parts carefully, I'm able to easily turn 33s on dry pavement (with one finger or the palm of my hand)Yeah I think about stepping up pretty often. Mine is old and pretty haggard, but I can't complain, it was cheap and has been awesome for 5 years
My bucket is slow, and seems to be crossed with the power steering...still works fine just very Armstrong.
I made the mistake of driving the neighbors new bx23 last year. Fingertip steering and a lightning fast bucket. It was freakish luxury...and wrong somehow![]()
It's a hydrostatic tractor, so not really similar to a car ps system.I know that the sardine can Saginaw pumps have a regulator on the outlet for the high pressure outlet. If the hole is drilled out slightly larger the pump's flow can be increased and by adding shims increasing the pressure. By selecting parts carefully, I'm able to easily turn 33s on dry pavement (with one finger or the palm of my hand)
I have no idea what kind of pump setup your tractor has... it likely could also be tweaked. The risk would be blowing lines or breaking old, and hard to find parts.
From the advertising when I bought mine "this has an independent power steering pump so to can steer and use the hydraulics"It's a hydrostatic tractor, so not really similar to a car ps system.
Pump is integral to the tractor, it runs everything. Engine is only there to provide power to it.
Pressure isn't the problem, got lots of that.
in my case it's possible the bucket is plumbed wrong, and also possible the diverter valve is allowing flow to both systems at once, which makes both slower and weaker than they should be.
Also quite possible both of these things are true.
It's not that big a deal, so I've lived with it. If it's a plumbing change I'll play with it, but if it's an 800 dollar part...I'll continue to live with it and think about upgrading to a slightly bigger machine.
Haha I saw that . It's hard to get perspective on how big it actually is.Look at this post on Facebook Log into Facebook - https://www.facebook.com/share/TcS49GiZ9zQ3LmyN/?mibextid=79PoIi
View attachment 3490658View attachment 3490659
I feel like this has @seapotato s name written all over it
Just need @Toshi38 to work on the price to be more what he’s willing to pay.![]()
It's really just pallets of pellets I'd ever use it for, and I'm not sure that could lift 2k lbs
I just end up taking lots of trips with the cruiser or the tractor. We hardly burn any pellets now that the heat pump is better set up. Most of the ones we have are for the father in law.
I want to install one of the little mini splits in his place so we don't have to keep ferrying pellets around but I know the cheap old f***er would just turn it off...![]()
Yep it's probably cheaper but we're dealing with an 80 year old east coast farmer here. Literally counts the pellets as they drop in...Isn't it cheaper to run the minisplit then the pellets?
Here it is a lot cheaper, until the temperature gets to around - 15 then it starts to get more even, although it still works fine until around - 25.
We are planning to put in a ground based system in the future, it's the same concept as the mini split but with the ability to take advantage of the more constant ground temperatures....
I got my parents when I explained that a heat pump gave around 5 units of heat energy for each one out in, and that basically whatever they do they won't be able to beat getting 4 free, if they have to pay for all... My mom loves free s***.. Buy one get 4 free is a good saleYep it's probably cheaper but we're dealing with an 80 year old east coast farmer here. Literally counts the pellets as they drop in...
He had a wood stove as his only heat source up till a few years ago when they threatened to cancel his insurance unless it was removed...in February.
Convincing him to just quickly throw in a pellet stove then was hard enough...by the time we won the argument that a heat pump is not untested modern technology he'd be 100.![]()
