Yes, the TPMS reads for 5 tires. If you remove your spare you'll get a warning.I have been trying to reset the tpms system to no success. Does the system need 5 tires on board to function/reset?
currently its displays "--" next to each tire on the mid. In addition it displays "registering each tpws sensor"Yes, the TPMS reads for 5 tires. If you remove your spare you'll get a warning.
Question: what do you mean, "Reset"? Do you mean that after you rotate all 4 (or 5) tires, to reset the TPMS to read the position of the tire correctly, e.g.: right front position reading: right front tire, etc.
The TPMS just reads tire pressure, there is no resting. On your 2020, you have individual tire pressure readings.
Not impossible, but can't imagine sensors being bad after only a few years. I finally had to replace mine after 10 years.When you start up, does it blink around 10 times? That means that the sensors are bad.
nope. They were working right before the flat so unless the reset destroyed the sensor kind of out thereWhen you start up, does it blink around 10 times? That means that the sensors are bad.
