So, Diesel gang…
the 1995 toyota 14B in my truck ran and started just fine. Then in my attempt to refresh all the filters when I got to the diesel fuel filter, it was a plastic inline filter that I decided to change back to the original spin on. I had glass beaded the housing, washed it in the parts washer and blew it dry. Replaced the in and out soft fuel lines from the tank and filled the spin on filter with fuel. For an unknown reason, the truck started…ran at a higher idle and blew loads of white smelly smoke in the air and black soot and the ground. Acceleration to a high speed with the pedal is slow and minimal and seems to bog slightly and …the smoke is very steady.
my assumption based on 2 opinions was that the housing which was original to the truck may have an air leak as they are known to fail. So, I went back to a new in-line fuel filter while try to minimize air in the line. ( diesel tastes like s#!t). Anyway had the inline filter 3/4 full…. Started the truck, it starts up easily with a press of the accelerator but is no different with regards to high idle with tons of smoke with soot.
I am waiting for a new spin on housing with the pump but I won’t be getting this until the end of May. I changed absolutely nothing other than to break the fuel line and swap the filters. I am missing something but I am not a diesel guy.
Does anyone have an idea what I may or may not be doing correctly?
