The drivers side I am having some trouble with. Due to my brushing skills it was not smooth. I hit it with 1500 grit wet paper. I was not getting the desired result so I hit it with some wet 420. This took it down to smooth but it now showed metal underneath. It was not quite at bare metal so I cleaned it, let it dry and hit it with another coat of touch up paint. Problem is I see the same thing happening when I go to sand it again. This is what the drivers side looked like before I started sanding.
This is similar to what it looks like now. What is the best way to go about this? I am considering leaving the blob so I do not screw anything else up. Do I put clear coat over the side I am happy with? I bought some from Toyota. I am having trouble adding photos from my Mac. I can try to add others if y'all can't see the mess I am making.
