Totally bizarre random turnover starting problem.
Over the years my '86 about three to four times a year would not turn over. Just a faint click.
The ignition lock is a bit worn out but it works.
So I thought to bypass the random problem I installed a starter button parallel to the start position wiring.
So far so good, two option to start her.
One day when it acted up again I discovered that it does the same with the starter button I installed. Click.
Ignition on, push the starter button and a faint click.
Now then, enter the bizarre:
When I put the truck in gear, let go of the clutch and rock (even while sitting in my seat) a bit back and forth, so the engine turns a minute bit, thereafter trying again, she turns over and starts just fine!
It's not the starter because when I check the latter all is fine.
It's not the grounding of engine/starter to chassis/battery either!
All is fine as well.
So WTF is causing this and why when (with not engaged starter) but ignition on slightly turning the engine as described above does all suddenly work again?
Hey Car Talk Click and Clack, Watchasez?
