Top heater nipple fj60 2F
Beehanger
Musically Inclined
Idaho
Hi all,
Trying to figure out how this heater valve/joint gets hooked up (the one on top of the engine)
I have plug off screw for the side of necessary. Which hoses go where?
(Desmogging btw of that changes anything)
Thanks,
Dan
Hi all,
Thanks,
Dan
are you installing the OIL COOLER set up ?
desmogging doesn't affect the heater hose routing
hose from firewall valve to vertical pipe in head
vertical pipe in head is missing piece that goes into the nut
the piece in the nut goes to the stub out the firewall down by cylinder 6 exhaust
there should be 2 ports on the vertical piece in the head
Hi all,
Thanks,
Dan
i have this part in circle red ink
Can I still fill the rig with coolant with this unattached? Like block off that port and heater hose or now, and put the vane on later. We’re trying to get this done today as I’m out of shop time
Hi all,
Thanks,
Dan
with the nipple setup toyota Matt shows you make connections as shown. The lateral port connects to the pipe that runs behind the engine along the firewall from your picture this pipe looks a little corroded. That pipe routes water for the rear heater. If you don't want to use that you can block off the lateral port and not use that pipe. The vertical port gets a long heater hose connected to it that runs behind the air cleaner to the main heater valve.
I offer usps over night EMS pony express shipping reserved fir special PLC status clients only
You are a PLC
So you qualify ..
Cut off time is very soon !!
Roger that. What do you do with the hose then if you were to block it off?
Dan
Notice the items marked with rear heater and without. I think most US FJ60s came with rear heaters so you may have to find an aftermarket match for the hose marked 87246A
The pipe 87248C is only used for the rear heater. All the parts marked with the star-shaped symbol are only used for the rear heater. If you don’t want the rear heater don’t use them and replace with the ones indicated “w/o rear heater”
Gotcha, but what do you do with the corroded hose? I have a plug for the pipe, but Just leave the corroded hose as is an it’ll run?
Dan
i personally like OEM parts options :
- we can simply install the hard line ELBOW and plumb the rear heater as intended
or
- we ca install the NEW OEM JAPAN Spec. snappy shut off valve and have the freedom of choice to use or not use the rear heater
- lastly , you can install the TALL TOWER at the bottom , and CAP all the various other NON-mentioned ports if you like too
- so 3 OEM OPTIONS on the table here
- :cool:
.https://vintageteqparts.com/collections/everything-else-hardware-fsms-shop-manuals-special-teq-stuff/products/copy-of-6-non-usa-oem-toyota-cooling-system-union-joint-fitting-cylinder-head-f-1-5-2f-3b-3fe
I’m looking to understand if that shutoff valve actually works on a 60? I bought one and installed it (haven’t fired up the motor yet). Matt, you left a comment on your Instagram post for this and said it would not work for a 60. So now I’m confused? Do I need the simple union with no valve instead? I’be deleted all of the rear heater parts and am not using a rear heater.
