Hoping to be around the middle of January, and I will get a KEG of Prelude for services and also a Reese peanut butter cup cake.time frame?
I'll help on moving day!
the problem comes in if you are running an electric winch. If you were to hit both buttons at the same time you would create a dead short across the battery through the relays. If you are going that route you need to add an additional circuit that kills one of the antenna switches when the other is pushed.
Using a rocker switch is by far the cheapest and safest way to go as by design only one side is pushed at a time.
Nice job Tom. Did you bend it yourself?
looking good Tom. will see how it holds up this sunday.
Mated the SM465 to the 3spd case and converted it from vaccume s*** to manual shift. Picking up a tbi 350 this week.
Finally got my full cage done:
