Todays wrenching (9 Viewers)
^Ok thank you that's good to know.
Picked up a nice set of used Corbeau Baja SS seats and 5 point harnesses for $150 off CL on Saturday.
Also I started to assemble the SM465 and 3spd case.
I wish people up here would sell stuff like that, always looking but never find that stuff.
Up there? They were on Athol. Closer to you than me. Sorry I did tell you why I was headed up there Saturday. :D
Guess I should check more than the NH list.
I find more stuff on the NH CL that I want to buy but some of its just not worth the trip. Thats where I found a $50 SM465. Seems there is more 4x4 related stuff.
You should also check the Western MA and Worcester stuff. A lot of that stuff is some times well north of Worcester.
Does anyone know if the seat tracks on an FJ60 have a wire going from the adjuster side (on the same seat) to the otherside to adjust the other track.
I have a set of 60 seat tracks I want to use to make sliders so you can adjust the seats.
methinks the 60 only locks on one side, other side just slides
Good deal Kina, Thanks. I was guessing that was the case as the two seats only had it on one side and not the other but it looked as if there could have been something there at one point.
^Looks familiar.
Actually got alot done today on the new-to-me 80.
Factory trailer wiring fixed, and new plug installed.
Rear sway bar installed ( took drilling&tapping 4 of the 8 bolts.
Pulled the entire nose off to fix a couple stupid issues.
discovered what i thought was a 5-6" lift is really just a 3.5-4" lift and 35's.
863J rear springs and OME 10mm & 5mm spring packers in the rear.
still unsure of the front springs & spacers, but it's level, so it stays in.
also fitted my 9000i behind the JDM bumper :) woohoo !!!
here's a few
9000i mounted in bumper
a scion headunit out of my 07 tC
and i bedlined from mid-door down after fixing some bodywork.
was going to take some of the lift out, but discovered what i thought was a 2" spacer was only a 10mm & a 5mm (1"+/-) spacer, so not worth ripping apart the whole thing for only an inch.
Pulled the dash and cluster to replace the [d] light and the CEL, so i could find out why the CEL was on.
3rd pic is my true wheeling rig. cj8 with recentered H1 rims, soon to be wrapped in 39.5 swampers, 4.0L out of 93 XJ, T-18 tranny, and a 4:1'd dana 300. Spooled front, welded rear axle 4.56 geared. final crawl is 73:1
Fun little toy, it's the 3rd jeep i've built since 2002.
Pretty sure My jeep heads out of the garage sunday to it's new home.
I like scramblers.
I had a cj that I was going to pull the 4.2 out and drop in a 4.0 and a aw4 trans and mate it to a d300 but I decided against it.
I still have the d300 to aw4 adapter and a aw4 if you hear of anyone in the jeep community looking for one.
I'm now trying to fill the garage with yota parts!
Send me a pm on details like price and condition and I can list it on the local jeep board or goto neow.org and post it there, that's where I hang out most of the time. Might actually know just the person for that.
the boy has been belly aching about the lack of attention his truck has gotten.n So I rebuilt the PS pump, replaced the leaking oil pump seal and crank gasket and found two bad TREs on the drag link.
This bill should get him off my back for a while.:p
