- Thread starter
- #41
@cruisermatt the power feed on x axis works wonderfully. The coolant pump, power feed and head motor are all three phase, adding up to 5.5a and 1.75hp total. The GE breaker on the side has a 1 amp heater in it, so the breaker trips whenever I turn a motor on after initial startup. However, I found that the heater in the breaker is replaceable, and can be replaced with up to a 17a heater. I ordered new heaters to upgrade the breaker to 6.4A, which means I'll be up and running by Friday!
I will use the vfd as a phase converter only, but it looks like doing so is favorable to using a static phase converter (can't afford a rotary phase converter). In addition, if I decide to rewire the machine entirely to use the functions of the vfd, I'll already have one.
I think it's a good plan! Very excited. Also ordered tooling to make the part I started this thread about
