Did not see the total weight of this winch![]()
My "shipped weight" with the winch and a tree saver strap(probably no more than 4-5lbs) is 62lbs. This includes the packaging material also.
pfran42 said:How to clock the gearbox: (NOTE: change made to step #7)
1. Engage handle to freespool.
2. Set winch upright on motor end.
3. Remove 2 allen bolts from tie bar gear box end.
4. Remove gear box by lifting up from tie bars.
5. 10 black machine screws will be seen on the foot housing.
6. Remove the ten machine screws that hold the foot housing to the gear box housing.
7. Turn foot housing 108 degrees (you can't rotate it exactly 90) from bottom so handle faces upright and very slightly forward when installed feet forward.
8. Make sure rubber gasket machine screw holes are lined up for the 10 machine screws to go through and hold gasket in place for correct seal.
9. Install machine screws working on opposite sides to secure foot mount level to gear housing. (similar to tightening lug nuts on wheel)
10. Make sure gear box drive shaft is set in brake. (in the opposite end of drum by motor)
11. Position gear box back over shaft and turn until shaft engages onto sun gear. (this can be seen as the base plate will line up and touch the tie rod)
12. Tighten allen bolt through foot housing onto tie rod ends.
It sounds like a lot more work than it actually is.
Did you mean 90 degrees instead of 45 degrees by chance?
Actually - you can go 72 or 108 degrees. Neither are directly on top - choose whether you want tilting slightly forward or slightly back. Slightly forward - 3 holes may be the way to go.
Take it off the synthetic line, feed the line through the fairlead and re-attach hook on the correct side.Excuse me for a newbie dumb question - how does one get the winch hook on the correct side of the fair lead?
What 80t0ylc said. Sort of. Completely unspool the line and disconnect the attachment to the drum. Then run that end through the roller or hawse and reverse the process.
You want to get to this point, then disconnect the line from the drum and feed it through the hawse/roller.
If he's got a roller fair lead, he can just pull the retaining ring off one end of a horizontal roller. Then slide the pin out of the other end to allow the roller to move out of the way and push the hook through. Then re-install the roller, pin and retaining ring.
Supra88 said:Ok - I have the hawse, so I'll unspool. When I clocked the gear box 108 degrees I had difficulty nesting the gearbox back on the spool. At first I thought it wasn't set correctly, but no matter what I did it didn't sit flush on the tie bars. I finally just cranked down the allen bolts, but the spool seems slightly cockeyed. When I release the clutch to pull out rope it is very difficult. Any suggestions?
