For me I have always questioned tire pressure. When I was younger I was very worried that my tires had the right amount of air in them and checked far to often, well ended up ruining two of the four and ever since always wondered what the heck to do. The part that always bothers me is the “bulge” of the sidewall. Other cars in the parking lot do not have this “bulge” why do I? So now having my Landcruiser I want to make sure and keep a close eye on where I am at.
Well I guess my question is: on the inside of the drivers side door they have a pressure rating for the stock size 275/70 R16 of 32 psi, the tires I have are a different size P265/70 R16, from the PO, and on the sidewall it says 35 psi when cold.
-So what is cold, if your truck has been sitting in the 80° heat all day you can’t check the pressure then right?
-If you drive one mile through the city to get air are your tires still cold?
-What if I am at 35 psi and the “bulge” is still visible?
-Am I making this to complicated?
-Any Tips?
BTW on http://www.esuvee.com/flash.html did you know it says never to use a tire bigger than the mfg’s says?!?!?! Crazy!!
Thank you in advance
Barrypt5
-Any Tips?
Barrypt5
