Tire Pressure BFG KO2's (6 Viewers)
Well the manager that was trying to work them out mentioned that he thought one of the wheels had a smaller bore size than the others but I ran calipers on them and that's not the case, so who knows. All I know is that they ran perfectly well for 5-6K miles then they re-balanced them and it was never the same, it all went to hell and they just kept throwing weight at the problem making it worse and worse each visit. At the end of the day I got new tires for no money out of pocket and things are better, hopefully they stay that way.
Take a look at my added edit above in case you missed it.
In any event, glad you finally got it sorted.
They utilized the centering cones.
Thanks for the information!
I’ve been running 35 PSI for this setup for almost 1 year now……(got them from discount tires)
13.5 MPG with a Frontrunner roof rack
Recommended cold PSI for 2016 LX 570, BFG KO2 LT275/70R18 Load E 125/122R?
My result from the Toyo Application of load..... is 42PSI
based on load rating of 2340lbs per tire.
