SOLD Tin cup Master cylinders.
sofj45
Supporting Vendor
Year
1965
Have a set of restored masters, clutch and brake both.
tin cups, master cylinder threaded plug ends were rezinc dipped with minor blemishes from years of use.
masters were taken to metal honed 2 coats primer 3 coats paint.
caps were taken apart cleaned repainted. have both styles of caps, early with the square nut and small pin hole breather or the later style as pictured with the rocker breather which ever you prefer for year of vehicle.
rebuilt using JBS rebuild kits. hand cut gasket using felpro material for firewall to master.
$500 for the set. shipped in med flat rate with added insurance.
i would do 100 as trade on core charge also if anyone wants to do a swap. 100 per master cylinder that is rebuildable tin cup master.
Is there any difference in amount of fluid moved by this style vs the side banjo bolt/late 60's clutch master?
Do you have it??
