Thud/Thunk - Front Driveline When Coming to a Stop*
Pittsburgh, PA
*To date I've only observed the noise after extended highway run times, so wondering if temperature is a contributing factor
The noise only occurs when slowing to a complete stop. Regular or quick stops with brakes applied. Coasting very slowly to a stop does not seem to cause it. NO noise upon acceleration. Suspension and brakes feel good with no noise or vibrations, as does the transmission, in all other scenarios
Day to day driving I don't experience the noise. It has only been on multiple road trips when slowing to pay a highway toll after hours of driving where I've noticed it. I'm fairly sure it is coming from the front or center of the vehicle
Does this sound like it could be transmission related on the 2-1 downshift? (and is only occurring when AT fluid reaches a certain temp?) It seems like if it were worn out bushings or other components it would occur much more frequently
Any thoughts are appreciated. This is on a 2006 LX with 95k miles. Plenty of "thud" threads around but it seems like most are different than this one
Mine did the same. I did new u-joints and took everything apart and cleaned out the old grease, thunk is gone.
I'm glad that is the first two suggestions
I should’ve mentioned I've not tried greasing u-joints/yokes yet (and when they were last greased is anyone’s guess)
That was going to be my first course of action, though I was a bit skeptical because of how infrequent the noise is
Hopefully (probably?) it really is as simple as that
The slip joints can take a LOT of grease if it hasn't been done in forever, like around a half-tube for each joint. Pump until you see the joint starting to move a bit.
Be careful overfilling the front driveshaft slip joint, or pull the zerk fitting after filling and drive around the block to let the excess ooze out. There is a theory (not mine) that the hydraulic pressure from packing grease in the front slip puts pressure on the front pinion. Thus causing front diff issues.
