I recently purchased an '02 LX470 for what I thought was a great price (6.5K guy was asking 7.8) it did have some front end damage which I was ok with as I know to repair could be 500-750...but took it to Lexus yesterday and they posted the below. I wasa never even asked about having any of the job performed, but anyway, what all do you think I should replace (rotors, pads, lines?) anything else?
" CUSTOMER DOES NOT WANT WORK DONE ~|~THE PADS ARE AFTER MARKET. NEED THE BRAKE PAD SHIMS. ~|~ ~|~CUSTOMER DOES NOT WANT WORK DONE,CUSTOMER DECLINED SERVICE -RECOMMENDED, NOT DONE-CUSTOMER DOES NOT WANT WORK DONECUSTOMER DOES NOT WANT WORK DONE ~|~THE FRONT BRAKE PAD FITTING KIT. VEHICLE HAS A LOT OF CORROSION UNDERCARRIAGE. IT MAY NEED FRONT BRAKE CALIPERS REPLACEMENT. ~|~ ~|~CUSTOMER DOES NOT WANT WORK DONE,CUSTOMER DECLINED SERVICE -RECOMMENDED, NOT DONE-CUSTOMER DOES NOT WANT WORK DONECUSTOMER DOES NOT WANT WORK DONE ~|~THE FRONT WHEEL BEARINGS HAS PLAY. TO PERFORM FRONT BRAKE JOB REPLACEMENT AND FRONT BRAKE ROTORS RESURFACE NEED TO REPACK THE WHEEL BEARINGS. ~|~ ~|~CUSTOMER DOES NOT WANT WORK DONE,CUSTOMER DECLINED SERVICE -RECOMMENDED, NOT DONE-CUSTOMER DOES NOT WANT WORK DONECUSTOMER DOES NOT WANT WORK DONE ~|~THE 2 FRONT BRAKE ROTORS HAS A LOT OF CORROSION AND THEY ARE CLOSE TO THE MIN THICKNESS SPECS. ~|~ ~|~CUSTOMER DOES NOT WANT WORK DONE,CUSTOMER DECLINED SERVICE -RECOMMENDED, NOT DONE-CUSTOMER DOES NOT WANT WORK DONE "
By the way, the rust is all BS, there is surface rust, which its being treated by removing all of it, cleaning then treating with proper metal rust preventative and then a lubricant to keep moisture away.
Thank you with nay help you may be able to provide.
