Thanks...since I am running 33's with the OME lift I will leave well enough alone...I too like to rail it around corners
calamaridog said:"I think if you have a locker and use it appropriately the changes of the diff breaking is largely reduced since you don't get the sudden shock load situation.
I broke a front axle and diff under exactly the same conditions. The front was open, one wheel lifted, heavy throttle, heavy truck, tire got traction and bang, it was over.
I think due to the independent part of the IFS system, the one tire lifting and then getting traction happens pretty easy, that is why we see it a lot more breakage on them. If you talk to 4Runner guys, they will break CV shafts when the same thing happens.
My suggestion is stick a ARB in it and use it when you need the traction."
Ok, so my question is this. How would the TRAC system affect the front end traction? Will it help reduce this shock load which can destroy the front end?
Cristo, was the truck you were driving an LX470 also when you destroyed the front end and broke an axle?
And breaking CV's is way better than breaking the diff. Easy/cheap trail fix there.
calamaridog said:George,
So what about running the Land Cruiser t-bars instead of the LX470 ones to help support the bumper and winch?
hoser said:It's not just stock T-bars... its stock T-bars plus AHC suspension. The AHC suspension supports some of the weight of the vehicle.
5151broadway said:Problem on the LX470 is that if you change the front T-Bar you loose the ride adj height. I'll just wait till it goes out and replace the whole suspension with the EMU stuff.
All this TRAC talk makes me want to get a newer model.
Thanks,
George
ChuckB said:Christo,
what's your opinion on the TRAC and ARB combo vs. just a dual ARB setup? How much/is there a "significant" advantage with TRAC and lockers? Meaning enough significance for me to purchase a '99 vs a 2000+.
My philosophy is that if there isn't that much of a difference then I could save some coin and buy a 99. If it is worth it, then I would try to buy an 03-04.
ShottsUZJ100 said:I bet Christo will answer though it's hard to answer unless you're more specific about what surface-type your speaking. I'll give an example:
In 2 weeks I'm riding a trail in AZ that has been closed for years (and still is). We finally got a permit after years of trying and are going. 10 truck max per permit. On this trail there are 6 insanly steep and narrow and very dangerous switchbacks to climb. Most take straps on a few for safety. Most will require a rear locker for sure. When your rear is locked your center is too (on a '99). This will make it hard to turn and increase the radius up these. Because of this and the danger, we're bringing the 100. Why? I can lock the rear for traction, have the center unlocked for turning ability, and IF I need more traction up front while climbing, I have TRAC.
In some situations TRAC-only is best. In some, lockers are best. In some, a combo is best. The bottom line is that with a TRAC-LOCKER combo you have all kinds of options depending on conditions. I've wheeled so long this way I can see this and run into these scenarios. My 80 is limited in this area whereas the 100 is not. You can add lockers...you can't add TRAC.
hoser said:Christo--when adjusting the lift to 2.5", should all the adjustments be made to the AHC sensors or should it be a combination of AHC sensor and torsion bar adjustment?
ShottsUZJ100 When your rear is locked your center is too (on a '99). This will make it hard to turn and increase the radius up these. [/QUOTE said:Why would the turning radius be that much more if this is a loose traction surface? The wheels will just spin. I can see not wanting the front locker on, but I would still lock the center. What if both your rear tires start spinning? The front is not going to pull.
sleeoffroad said:Why would the turning radius be that much more if this is a loose traction surface? The wheels will just spin. I can see not wanting the front locker on, but I would still lock the center. What if both your rear tires start spinning? The front is not going to pull.
