Cdaniel
Undocumented Mechanic-I Am Not CDAN
Are you aware of any known reason to look for that would make mine really resistant to shifting from 3 to 2?
The problem started long ago when It got into a really bad locker buck around a corner. I popped the top back then looking for something obvious on a synchro, but nothing jumped out at me.
It's getting all new seals at the least and maybe synchros during my current revitalizing project.
A weak link on 465s is the snap rings that retain the gears on the counter shaft. Wear on this allows the gears to move on the shaft and it will pop out of 3rd gear. GM made an updated countershaft spacer to replace the snap rings and prevent this problem. It is a $10 part. Pull the top cover and see if it is installed. You may want to rebuild it and add the updated spacer if it has not been done yet.
