Things to check before a road trip in an 80
North Carolina
I have searched for a similar thread. Haven’t found one so I am making my own. Getting ready to take my 80 on a road trip. I believe all of the baseline maintenance has been done by me. All Fluids have been changed and some flushed, hoses, belts, fan clutch, valve cover gasket, radiator is good, although I’m sure I am missing a few things. But I know these are at least 26 year old vehicles so I can’t expect perfection. I wanted to post and see if there is any kinks I need to check out with mine before I embark. Tons of guys on here who know every square inch of an 80 so I need some advice. Thanks guys. Also looking for the “ where has your 80 taken you” thread. Can someone link it ? Thanks.
I always check to see that I have a full tank of gas!
devo
Check yet nutz!
Deez nutz
Check
Oil
coolant
Brake fluid level
Wheel bearings, make sure they aren't loose
Belts
washer fluid
Blinker fluid
Tire air pressure
Spare tire air pressure
Have a quick look underneath for anything that looks out of place, or leaking
Replace the heater T if you have not within the last 50k miles. Cheap easy part but catastrophic if you have failure.
