Looking to change out my thermostat and wanting to do it my self. What are some tips?
Make sure it's only OEM parts. I had an aftermarket t-stat installed from the PO that was slow to come up to operating temp and had pretty wild swings in temps per the Scangauge. New genuine Toyota t-stat comes up to normal operating temps quicker, and holds normal temps a lot more steady.
Remove the heat shield that covers it. 3 or 4 bolts. I had to remove that in order to get a tool on the top nut.
I was able to get to all the fasteners without removing the heat shield. One is a little tricky but you should be able to get it. Careful if you decide to remove the heat shield as it could lead to broken fasteners.
Are people referring to the exhaust manifold heat shield on a 1FZFE when replacing the T-stat??
IIRC I used a socket with a short extension for the bottom nut and the top front nut and a box wrench on the top rear nut.
