Hi all, I am in need of some insight from those that know the workings of the cooling system better than me.
What I have: 1987 fj60 with 90s SBC.
My issue: the engine temp goes up to about 3/4 or closer to redlining in the initial heat up of the engine. Once the engine hits the 3/4ish mark it begins to cool down. After that it seems to run too cold. The temp guage reads about 1/4 maybe up to half after the initial warm up. I live in a very cold place during this time of the year so my heat isn't that great with the engine seeming to be running cooler than it should. My guage and radiator are stock fj60 parts.
My assumption is my thermostat may not be the correct temp or it is sticking or something. I am wondering what you all think might be going on here. I plan to replace the thermostat, but I am not sure what temperature thermostat I should go with. Winters here are very cold, usually not getting above freezing during the winter months, somewhere between the negatives Ferenheit up to freezing. Summer time we might see 80s once in awhile, but I also want to make sure ill be good on trips to hotter climates.
I'm not sure if my thermostat is too cold, too hot or what, so any help is very much appreciated!
