Ok thanks so much! i really appreciate it!
but wanted to add my thanks to Spook50 for not only coming up with this mod but documenting it so well.
The shifter in my 62 was incredibly loose, as in there weren't any stock bushings left in there at all. Well, not any more.
Details.
I found the bushings at an Orchard Supply Hardware store, same dimensions as the Hillmans but different brand I guess. They were in the vertical racks of specialty hardware that seem to be at every OSH I've been in.
Probably could have found some at my local True Value too but they were closed last night and I wanted to get started on this early today.
I didn't do the pin mod, didn't seem to need it but I might go back and do the set screw idea later.
The bushings took a bit of work to get turned down, I too used the threaded rod part of the linkage and chucked it into my drill press to make a vertical mill of sorts, used a small flat file and then some emery cloth to smooth things out.
Worked like a charm. Used an allen wrench as a lever to make sure the linkage didn't fall thru while I was fitting the bushings. Put a little moly grease on the inside of the bushing as well as on the inside of the collar part of the linkage.
Thanks a bunch, it's fixing the little stuff that makes me really enjoy the FJ so far.
John E
Hey! I came up with this idea. Spook50 just copied and improved on my idea.![]()
Did you ever get an answer to this? About to attempt this fix but I had the same thought...Metric bushings likely wont need much "lathing".Hillman part# 882995 appears to be a SAE 5/8" x 3/4" bushing; would anyone have a new OEM bushing they could measure in millimeters (ID x OD x L)?
