Alright, the following has officially driven me crazy. First, a little background.
I got this Fj60, Sue, from a friend for cheap. Entirely stock 2f engine. It had not passed emissions for years, and I have still not been able to register it in my name because it does not have an emissions pass. That is part of the problem.
The day after buying it I took it on a camping trip, and after making about a half an hour into the mountains smoke started billowing out of the engine and I found myself with a seized air pump. Luckily I broke down in Idaho Springs and luckily Idaho springs had an auto parts store that just so luckily carried the belt I needed to bypass the air pump. I eventually switched out the seized air pump for a rebuilt OEM pump. Talk about opening a can of worms.
In the last 10 months I have done the following, mostly in an effort to pass emissions:
- replaced air pump
- switched to saginaw ps pump to prevent leaking and another seized air pump
- new vacuum lines and made sure they were routed correctly
- New EGR vacuum modulator
At this point I am noticing that the truck smells terrible. Sort of like exhaust, but not quite. It gets to the point were I can't drive anywhere without my clothes getting covered with the smell. So I start trying to fix that problem:
- new exhaust/intake manifold gasket
- welded crack at exhaust to manifold flange
- installed rebuilt carb from cruiserparts, tuned with lean drop method.
at this point I went to get emissions checked again and had about 4x HC and nearly 10x CO limits...
So then:
- went through emissions components bit by bit as per FSM
- found that nearly every single part of the AI system was faulty
- replaced every faulty AI component (VSV(1), VSV(2), check valves at air rail and exhaust, ACV, new "gas filter" which gives vacuum to the AI system)
- checked cat with infrared thermometer, works fine
So after that bit of work I run into another problem.
Anytime I try to go above 55-60 mph, the beast just starts sputtering, misfiring pretty badly. Even worse on an incline. I'm not sure when exactly this started, because I hadn't driven on the highway since before I replaced the manifold gasket. Around town it is running amazing. Idles beautiful, vacuum is a solid 16hg. Occasional misfire on decel but not always, and not a very strong backfire. Still stinks like crazy.
I think either the rebuilt carb is not right, or I still have an exhaust leak. I just don't want to spend an entire day going through those two without getting some more opinions.
I need to get emissions tested again soon, but the test requires the car to get up to around 60mph and I'm worried that it won't make it. If anyone has any idea whats up, I'd be very very happy to hear.
- replaced air pump
So then:
