Thanks! We tied the rock lights into the factory running board harness so they come on when you unlock the truck with the key remote. They will also be switched so that they can be turned on with a rocker switch. Going to tap into the factory harness at the driver's kick panel to do that thanks to
@Ramathorn15 sending me the connectors I needed and sending me wiring info on how to do it. There are rock lights at all four corners, and under the middle of the sliders. They give off a nice perimeter light.
I knew I was going to want some additional lighting while driving on the street, so I threw the SAE compliant Rigids into the slot that I assume is for additional cooling if the ARB bumper was installed on a diesel model. They JUST fit in the slot, and I had my guys weld a bracket deep inside that slot so we had something to mount the lights on. I won't really have Left/Right adjustability, but I can at least aim them in terms of height. I run those lights on a couple of other trucks and like how they supplement the stock headlights.
The only thing I didn't think ahead on was the size of the Baja Designs lights, and whether they would fit on the tab that was already on the ARB bumper. They are too big to slide back enough to actually use the hole in that tab, so we had to drill a hole a little farther forward so the light would clear the upper bar. Not a huge deal, but still bummed I missed thinking ahead on that when I had planned out everything else already. Doing all of those things before powdercoat was my goal, but that one slipped by me.
I'm really pleased with the color combo. It's not an exact match to the truck, but it is close enough that it harmonizes really well.
There is still some wiring left to do, but it's getting close to being done in terms of fun add ons. I got a scan tool so I can read AHC pressures since my Mac Book refuses to load VB so I can run Techstream. I plan to get the current readings, flush the AHC, get the pressure readings again and then determine the next course of action. It doesn't look bad like it sits, but I think it would look just a touch better if it was a little taller. I'll probably do the sensor lift depending on the pressures I find as it sits now that it's loaded up with bumpers, etc.
