I need to redo mine and just picked up the gasket. This thread should help me out. Thanks
Well, I did it over, using the same gasket. Last night, I drained the oil into an open top container, then let it drip overnight.
This morning I transferred the drained oil to one of those Blitz 10 quart oil containers that has a large top with a screw-on lid and a screen for letting the oil drain into it, and a spout with cap for emptying the oil. The nice thing about this container is that it keeps the oil bottled-up and clean while you work.
The I unbolted the oil pan and inspected the gasket. As I feared, the saddle that is to seal on the #4 main bearing end had been pushed toward the front and the sealing surface on the block had pressed into and distorted and cut into the cork.
I cleaned the gasket at that end thoroughly with acetone. The gasket was glued to the pan with Pliobond and I very carefully lifted the saddle end gasket off the pan .
After the gasket dried, I spread some Permatex gasket maker over the damaged part of the cork, smoothed it with a putty knife and let it cure.
Before returning to the Land Cruiser, I used a white marker pen to number all the bolt holes on the pan in a "spiral" pattern. Meaning, I numbered the middle hole on one side as 1, and the hole directly across the pan as 2, then dropped down one hole on the #2 side and marked that hole 3, then directly across the pan to the opposite hole from #3 and marked that as 4, then straight up past #4 and #1 and marked that hole as 5, then across the pan and marked the hole opposite #5 as 6, and so on, and so on.
After sliding under the Land Cruiser block, I had the 22 bolts in a container near me and also half a dozen longer bolts of the same size and thread, and I took two of the longer bolts as suggested in this thread and lifting the pan into position, ran a long bolt into a block hole in about the middle of one side, and another long bolt into a hole directly opposite to hold the pan while I fiddled around trying to get the damaged end of the gasket into the right spot. (thanks CardinalFJ60)
It took some doing, but using another suggestion from this thread (thanks Poser) I used a right angle pick tool to tease the damaged saddle shaped gasket into its correct spot on the #4 main bearing end of the block. This took several tries and at one point I was about to give-up, but with much juggling how tight the long bolts were and how far I had teased the saddle end out toward the rear of the pan, it finally looked good-enough to tighten the long bolts to hold things in place then thread two regular bolts into the last two and opposite holes on the #4 bolt end of the block.
Then I began installing the remaining 20 regular bolts through the pan and into the block according to the "spiral" pattern given by the numbers I had written on the pan.
I was careful not to tighten too much and made several circuits around the pattern. I used a Phillips screwdriver to do the tightening, being fearful that if I went with the ratchet and socket I would over-tighten the gasket and get a leak.
Then I poured the stored oil back into the engine and when I was satisfied there were no leaks, I started the engine and took the Land Cruiser for a spin around my neighborhood. Still no leaks, and tomorrow I'll recheck the bolts and tighten any loose ones in the spiral pattern then try some highway miles and see if it all holds-up.
Don't use a cork sump gasket just clean both faces and apply a good quality silicon gasket maker.Yes, can be very frustrating. I put the gasket on the pan and secure the corners with string and every two holes or so with string. Once the pan is up and there are some bolts holding in place I will cut the string and pull it out. This method seems to work pretty well. I also use black RTV on both sides of the gasket.
HTH
Posers method, cork one piece gasket. No leaks...easy peasy.
If the side cover for the push rood access was any indication of how the pan gasket was previously installed, I'm sure I'll have my work cut out for me getting it removed. The side cover gasket had enough black RTV on it to seal up an elephants hiney hole. It took lots of gentle, but persuasive prying to get it off, as well as some serious prep work for the cover side. The gasket was completely incased in RTV.
Also, if I looked it up right, the bolt size is an 8x1.25. Can anyone confirm this? I could just pull one out and take it to the hardware store to size it, but that seems like the right size from looking at it.
