Thank all of you for stopping by:
All brake fluid is technically synthetic, since they are mineral based.
EDIT:
Did a little quick research, Toyota's Dakar rig is sponsored by Motul, most of the teams sponsors are suppliers to Toyota, so thats probably the brand that is in the LC from the factory. Motul RBF600 is pretty sweet stuff
This is what I've heard with DOT 5 being silicone based. I for one have been confused by the marketing use of the word synthetic brake fluid.
Nice research on the DaKar w/Motul.
ive used castrol gt lma dot 4 in the race car and like it. its cheap, and you dont have to worry about fluid incompatibility. imo even thats a waste. brake fluid is held to a pretty high standard. even the cheap dot 3 (or whatever) still has to meet temp standards.
-google BITOG and read the brake fluid sec.
Glad you like the Castrol. I put the Castrol synthetic LMA in a used Chev Van, I based-lined. Subsequently I read in a web page form a brake pad supplier: "don't use synthetic (I wonder if they meant silicone based) or it may cause leaks". This concerned me, but no leaks or problems as yet, but it's only been in for 6 months and 2,000 miles.
Thank for the BITOG suggestion, I'm rooting around in their now.
dot 3 is stock in the 2000 fsm. rbf600 is 14.99 (on sale)for .5l so youd need a few. its also red.
-sorry about the typos.
Thanks for the heads up on the DOT 3 and the cost on DOT 5.1.
DOT 5.0 is silicone - DOT 5.1 is not.
5.1 is compatible with 3 and 4; and, around here, is the only thing the toyota dealer deals.
5.1 might be the best all-round for most of us, but it's not like higher dot is always better for any application. There are dot 3 fluids that can take higher temps than stndrd 5.1.
And then there is this thing about moisture. There will always appear some moisture somewhere in the system. What is the best then - with 5.0 the water stays separate from the brake fluid and can freeze, or cause corrosion. Then different types of 3, 4 & 5.1 will absorb water at different rates, which alters the quality (eg boiling point) at different rates.
The best fluid could be the one that changes the most when absorbing water, so that you would have to change it monthly, or after each race if that's you game. So maybe that's not the best for most of us after all.
Compromises, compromises.
uHu , Thank you for stopping in and posting. uHu,You really seem have a handle on this subject and are a very comprehensive and talented writer.
?? Let me ask you and any others that may wish to respond: What, if any, concern are their when choosing a brake fluid with the ability to protect and condition the seal and which brand is best when considering the seals (rubber)?
Since my brake system's old fluid was like new with no leaks, I feel that the brand used was very compatible with the seals and this protecting of the rubber is my biggest concern. No leaks is law in Japan, which would keep Japaneses Auto makers on their toes to match fluids and rubber very closely.
____________________________Of Interest________________
Toyota has been having a lot of recall issue since about 2005, blaming the fluid maybe a smoke screen maybe not. Below is from a forum in BITOG:
[Both Toyota and Honda recently announced recalls regarding brake fluid leaks.
Toyota, Honda launch recalls over brake fluid leaks - USATODAY.com
"..............But this recall was unusual in that both automakers said the problem wouldn't occur if owners had simply followed automakers' recommendations to
use only their branded brake fluid.
In its filing with U.S. regulators, Toyota said its brake fluids contain polymers that act as lubricants. If the wrong kind of brake fluid is added, a rubber seal in the brake master cylinder can dry out and curl, causing the leak.............."
".................Toyota has since revised the master-cylinder design so that it holds up to different types of brake fluid."]
A Note:
I feel the series 100 is one of the best engineered and built vehicle in it's price range, ever built. I like OEM parts as they consistently meet with spec (they fit), that said; Toyota parts, filters and fluids like all auto manufactures tend to use suppliers they favor, and a great deal of emphasis (favor) when choosing a supplier is with the lowest bidder. The point being; the factory installed fluid in my 2001 series 100 did it's job, but what is on the parts counter at the dealer today may or may not give the same protection.
