ChaseTruck
Have you tried the IAC reset procedure I linked earlier?
Once I put it all back together with a new OEM part. Boom. All was good. The CEL was gone for good. Or burned out. LolOurs was doing the same. She also tossed a P0100 and a P0110 codes. I pulled the MAF and cleaned it. I also cleaned the connections and then I found a huge crack in the intake hose in between the corrugated pieces.
That’s a good idea, I’ll do that today and then if it doesn’t seem to have that affect I’ll go through the procedure @ChaseTruck posted. If that still doesn’t fix it, my next step would be to take the plenum off and inspect/replace all the vacuum lines and valves under there, although I won’t be able to do that for at least a couple weeks.One thing I noticed when troubleshooting my idle issue was, with truck off I disconnected the IAC. When I started the revs went to about 1800. Shut off truck, hooked up IAC and when started revs went down. This told me the IAC was functioning.
I took the tube off yesterday and didn’t see any cracks, nor did I ever feel or hear it sucking in air from around there.Ours was doing the same. She also tossed a P0100 and a P0110 codes. I pulled the MAF and cleaned it. I also cleaned the connections and then I found a huge crack in the intake hose in between the corrugated pieces.
Also I’m still not throwing any codes which is really weird to me. If there was a huge vacuum leak somewhere, I’d expect it to be running super lean and therefore be throwing codes from the O2 sensors at least. With that said I STILL think it’s a vacuum leak lolOnce I put it all back together with a new OEM part. Boom. All was good. The CEL was gone for good. Or burned out. Lol
Alright guys, I wanted to update this thread. So I did actually find a vacuum leak on my engine; there was a small section of the valve cover that was bowed out (I don't know why) and allowing air to come in. Unfortunately, this vacuum going through the valve cover had the side effect of pushing a bunch of oil up into my TB and intake, so that's a bummer. Once I took the whole valve cover BACK off and fixed it, the engine idled pretty well. I also advanced the base timing to 7 degrees BTDC.
However, it still has some idle quirks. When I put the trans into gear, the RPMs drop to around 400 and the truck becomes very shaky. I thought the RPMs were supposed to increase when you put it in gear? Could this be something with my kickdown cable needing adjustment?
Hey Everyone,Also I’m still not throwing any codes which is really weird to me. If there was a huge vacuum leak somewhere, I’d expect it to be running super lean and therefore be throwing codes from the O2 sensors at least. With that said I STILL think it’s a vacuum leak lol
