MoJ
Moderator
You stated you cleaned the TB and replaced the gasket - you would’ve had to manipulate the main rubber giant black intake tube.Nope, TPS was not removed. I just unbolted the throttle body and set it aside, but I didn’t remove anything from the throttle body itself.
The truck was running fine before the service, and I didn’t take the intake off. I’m also in SoCal so during that time the truck didn’t see any temps below 45 or above 90, so I highly doubt the intake cracked, I will check it today while I’m looking for vacuum leaks.
I used the 93-94 kit from HuddExpo, which includes the dummy connector that plugs into the harness. But I thought only 95-97 needed the diode, no? Either way, the truck isn’t actually throwing any codes right now, which I would expect it to if it was an EGR problem.
