I tried this, but it depends on if your headunit supports it. My Kenwood has GPS/time-based dimming, not based on dash lighting voltage.The install was simple enough with the correct harness adapter. Metra 70-8112 is the model number and is available on Amazon for about $5. Pretty plug and play, 5-6 wires need to be connected between the new stereo and the adapter harness. Hunter now has streaming Bluetooth for tunes and hands free phone. Sound is much better too.
The only down side to the harness is it doesn't have a connection for the auto dim feature, I will have to go back in at some point and add that wire to the Metra harness. Maybe I never will...
Funner, when installing stereo did you have to run a wire to emergency brake switch? I am wondering if this step is neccesary.
what is all this stereo talk about - don't you guys rather want to listen to the engine and all the other noises the truck makes
y'all need a 40 - that'll cure of the stereo disease![]()
There is no cure for the stereo disease.No just means I would have to build a bigger stereo.There is no cure for the stereo disease.
