Tech Questions Here (11 Viewers)
Rouque advertised a bender on Mud for awhile that could do 180* bends and uses a habor freight jack with air over hydraulic. See lots of people use 1.75" DOM.
Got a problem with my 7.3, the CE light came on and it running like crap missing and idling rough. If im going down the road and the RPMs are holding steady around 1200 it shakes like crazy but if i speed up or give it some skinny pedal the shakes lessen alot. also it doesnt have much power at all.
I dont have a code scanner and i cant get access to one up here, anyone have an ideas?
need more info year mielage etc but with out a scan can be most anything.
99 f250 253000 anything else I really don't know. I'm gonna try doing tune up and oil change stuff cause I really don't know when any of that was last done.
tune up? like what ya gona tune ??
life blood on a power stroke is the oil! change fuel filter as well check coolant quality all can`t hurt.
but without a scan ya just pissin up a tree need to C what the ECM thinks is wrong & go from there
Tune up as in: change air filter, oil, and fuel filter. check coolant and other fluids. I'm gonna see what they have for sale around town for scanners.
HF`s top of the line unit is cheap & dose a pretty good job not sure about diesel parameters though
as for oil buy the best ya can afford Power stroke can & do exceed 3300 psi
I was gonna recommend that when I read the first post not a lot to tuneup on the diesels but that's a good start, I have a scanner if you wanna come borrow it :lol: Good luck bud I hope its simple :)
diesel oil how many qt?
Need to replace the little plastic 90 degree clips that hold the linkage for the door handles on the 4Runner. The lock mechanization linkage . Other than the local dealership would anybody have a link that I could order from to get in before the SCC ? Thanks
Yea I guess I could check the help isle at the auto parts store .
Guys anybody have a battery cable crimping tool (hammer type or pliers type) I could borrow for a day ? I’m building new cables for the winch and the cables on it naturally are the wrong length for how I am running them. TIA.
Wish I did Albert I could use one as well I guess I need to invest in a hydraulic with the dies to do the battery and winch leads.
can get my hands on on one that will due up to 4.0 will that be big enough:)
