Tech Questions Here (21 Viewers)
Or just beat the **** out of them until they sag a little.:flipoff2:
They're certainly broke in and should ride well they did for me. Only thing you may have to add is some shims up front I have 4 degree shims but depends on your shackles I have greaseable BTB shackles somewhere near stock length.
http://coolfj40.stores.yahoo.net/shimsspring.html
Also may need to do a leveler block after you get the springs on you'll just have to see its a common thing to add one in the rear if you have a lean.
Leveler Block FJ40
Shackle reversal improves the ride a little better axle travels rearward under compression rather than forward as it did from the factory. The kits now a days are much better than they were 15 years ago when people were cracking the transfer cases. Some do the reversal when they add the saginaw power steering.
No agent for cool cruisers I just used them because you can navigate their site fast for posting samples.
Any body have family or friends in Chattanooga, Tennessee that could look over and test drive a 80 series for a friend that works with me?
Not in Chattanooga :frown: but can ask a few of the SEC boys I chat with here in the forum. I'll get back to you with what I find.
No luck there Albert my other option would be to post a thread in the STLCA forum I'd bet someone would be happy to help a fellow mudder out and go look at it. I know we do the same for them when they ask for help.
TN- STLCA
Lets say I want to get my truck lower to do some work under the hood, would it hurt anything to jack it up, take off the wheels, and then set it back down on the brake rotors, the jack stands I have are not much shorter than if the truck is just sitting on flats which is already a lot easier to work on but lower would be even better.
put ya a 4x4 under the knuckle so as not to bend brake rotor shields
how about you get those 'steps' you hang on the tires? that'll give you a lift ;)
check fuel pressure
power to coil when key is on start & also run mode
temp sensor for ECM
idle air control valve
need to determine if its loss of fuel or ignition or management
Still know luck, change the fuel pump,d...cap,roter,pick up:bang: Sometime it will start and you can drive it, kill it start up and you think its good then it does it again. Drove it to Auto-zone, know :censor: luck over there.:mad:
engine light on y/n?
if so codes?
when ya have a no start do you have spark at plugs?
do you have fuel psi?
injector pulse?
does it run till u turn it off or dies on its own?
I posted over there and we'll see how it goes.
if so codes?
injector pulse?
F-I-L got it fix, was the computer on the car. Go figure:hmm:
Hey albert I'll call tina's cousin that live a couple hours away and see if he can go check it for you I'll let you know something tomorrow
Looks good to me Matt, I'm no roll cage expert but something is safer than nothing and this looks like a solid design especially with the center support to hold the frame of the cage if there was a roll.
In-Cab Cage Kit
Thanks Matt but it sold Tuesday :frown:
i like that cage , im gonna get it for the buggy , cuz i do plan on being un safe with it lol
Over kill, all you need now 5 point harness then you be good.
You don't need it bud you have the Exo on there, I'd save that money for a new frame :D
The seatbelts are great for securing you in the seat bud but thats not gonna protect your noggin if the roof is crushed in when your rolling off a rock slab :whoops: which none us plan to do but better safe than sorry and a good investment for longterm use.
attachment.php
Something looks wrong with that pic.... i hope know body got hurt.
attachment.php
Is there a story behind this pic Larry?
So if I read this correctly you think should have an interior cage as well as exo skeleton on off road vehicles ?
