- Thread starter
- #1,421
Or just beat the **** out of them until they sag a little.![]()
They're certainly broke in and should ride well they did for me. Only thing you may have to add is some shims up front I have 4 degree shims but depends on your shackles I have greaseable BTB shackles somewhere near stock length.
http://coolfj40.stores.yahoo.net/shimsspring.html
Also may need to do a leveler block after you get the springs on you'll just have to see its a common thing to add one in the rear if you have a lean.
Leveler Block FJ40
Shackle reversal improves the ride a little better axle travels rearward under compression rather than forward as it did from the factory. The kits now a days are much better than they were 15 years ago when people were cracking the transfer cases. Some do the reversal when they add the saginaw power steering.
No agent for cool cruisers I just used them because you can navigate their site fast for posting samples.
but can ask a few of the SEC boys I chat with here in the forum. I'll get back to you with what I find.
Sometime it will start and you can drive it, kill it start up and you think its good then it does it again. Drove it to Auto-zone, know
luck over there.
