I'm trying diagnose a lack of power issue and would appreciate any ideas or advice.
Vehicle - 1988 Toyota Landcruiser
Engine - 2006 LM7 (returnless fuel rail; corvette-style filter FPR at/near the tank; I also have an additional fuel filter between the fuel pump and the corvette-style filter/FPR)
Fuel pump wire is grafted into stock harness to control fuel pump; it is not connected directly from ECM to the Fuel Pump
Issue - I’m experiencing low power under load/at high RPMs; I measured fuel pressure at the rail. At idle it’s 58 PSI exactly; at high revs (~3-4K) the fuel pressure drops to 20 PSI.
I think there are three possible causes for the low fuel pressure:
1. One of the two fuel filters is clogged (could be, but why good pressure at idle and low under loads? Need to get my a$$ under the truck and check)
2. Stock fuel pump is old/weak (do fuel pumps die suddenly or just weaken over time?)
3. Stock toyota body harness wiring/relays is causing a delay in fuel pump signals/PWM (should I connect the fuel pump wire directly from ECM to Fuel pump?)
I'd appreciate any advice you LS swappers can provide.
