CRR 2024 Saturday Swap Meet!
I'll haul this stuff to RR if I get a decent offer:
80 series parts:
  • F/R OME 3-1/2" "J" lift with new caster bushings, Metal Tech caster plates, and "L" shocks
  • Rear Dobinson 4" rear springs
  • LX450 console
  • Factory radius arms with good bushings - cheap
40 series parts
  • Early bare windshield frame with the hole for the cowl vent, frame only
  • Early door handles
  • good starter
  • Gauge cluster
  • Weber 32/34 carb that worked great on my 45
General stuff:
  • 48" hi-lift with cast base
I will take the door handles
I have a set of OME heavy leafs for a 60 series. Probably 15 years old but less than 10k miles. I pulled a rear leaf out but it’s included. No bushings. Was on my truck before switching to Dobinsons. $200 OBO.
Pic on my truck with a leaf pulled in the rear and loaded with gear.
I have four of these from a first gen sequoia if anyone is interested. Tires are old. Rims are good.
These will fit many Toyotas, but I know the center caps won’t work on a 80. These are 16”. Also have a set of 18” rims for an infinity m37
I've got a Fauxwing 270 awning. Two of the arms are broken. I bought parts to fix it but never got around to it. I ended up buying a OVS 270 that is bigger.
2 good beers and you can have it and all the parts I purchased for it. The parts alone are $40.
The two of the cast aluminum ends broke. The rest is fine. Canvas in great shape, bag doesn't have any holes, comes with support rods, and mounting hardware.
Deployed on the beach.
Weld together U Bolt skids. These are designed for FJ40 and should fit Fj45' 55's and 60 series. Not pictured are the rear shock mount that attach to the the rears.
I have 3 sets of 4. Asking $70 per set obo
All material is 3/16 steel. I have designed these to not crush in like most others do by adding the center and side supports.
What's your preferred beverage
It's already been claimed.
I will be bringing other stuff camping related.
Hammocks, inflatable sleeping pad, tarps, military container, and whatever else that I find.
Anyone want new Toyota OEM spark plugs for the 2GR-FKS Tacoma V6 engine (2016-2023 I believe?). Trade for some beer, otherwise open to anything.
Anyone going have 1 or 2 old 37's on 17" wheel? I'm in need of some spares. Looking for an a/t or m/t with a decent tire date code. I'm game for cash or trades.
I have three Yokohama 37’s on Toyota 17’s. It’s actually a set of four but was planning to keep the best one as a spare.
They’re only 3 years old and hold air fine but tread is roached. Perfect for spares.
Kinda heavy to drag up but I have a 40/45/55 full-float rear available. Was going to list for $500 but would take $400. Needs brakes. It’s from a 78 so should be fine-spline 4.11 third. Little crusty but should clean up with sandblast.
1fz 80 Series parts
Can bring to RR given enough notice
-Safari snorkel and fender. $250
-OEM radiator. Red only. Approx 5yr/15k miles. $200
-rear driveshaft. 1/4” DOM tube. OEM joints feel good. Don’t recall time of replacement. After 2016 Slight out of balance. Small vibrations above 70mph. Great wheeler shaft to swap in $100
-very recent OEM front calipers/pads $200
- e locker guards f/r. $50 ea
-OEM diff switch and harness $100
-f/r pass doors and Tailgate $200/ea
-1/4” aluminum tailgate cover $100
-James baroud explorer evo RTT with cold weather kit $1200
-front runner tent quick release sys. $250
-ARB awning. 8x8. $200. Bag has a few holes
-pair of oak OEM non droopy visors $50
-SOR cargo area carpet. Great shape. Oak. $120
-homemade wooden drawer sys. Make offer
-front runner 14gal water tank $175
-LCP tcase shifter extension $20/tasty 4 pack
-attic rack homemade $25
-Landtank MAF and 4.7 sensor $150
Messaged you.
I have a ton of this boxes. I bought a lot of them. I also have the bigger ones. $130 small $150 the big ones. Condition changes because they are military boxes used to transport electronics.
1fz 80 Series parts
Throw the e locker guards in my pile too! I will pick up at RR.
