For Sale Tampa/Gainesville, FL: 10/1985 FJ60
Year
1985
  1. 60 Series
Mileage
326722
Color
Brown
1985 FJ60 (October)
⦁ Engine was replaced by PO with strong running low mileage 2F w/ Aisin carb
⦁ Desmogged (retains EGR, distrubutor NOT recurved)
⦁ New H55 5 speed installed by previous owner, approximately 1,500 miles on it now.
⦁ Location: Tampa/Gainesville, FL
Older thread with more info!
I have had this FJ60 for a few years and it has been fun to drive and to work on. I had a 40 that I did a load of work on before this and while the 40 was fun I didn't feel real great about piling the family into it. The 60 has been super fun and was a great addition. I am selling because the family has a big moving coming in the next few months and it is time someone else gets to enjoy this truck. If I move to a place with enough garage space then I would consider keeping it, but again, it may be time someone else gets to have some fun. It runs well and would be a great vehicle for someone to turn some wrenches. Always stuff to work on on an old 60, am I right??! I have a load of pics and will include as many as possible. If someone would like more pics I am happy to send some. I know the market is wonky and I am not under the impression this is a restored 60. It needs some work and has some great bones! I am happy to answer any questions you may have.
Work completed during my ownership:
⦁ Transfer Case rebuilt using Koyo bearings (Kit supplied by Georg)
⦁ Clutch Kit (Aisin) incl. Pilot bearing, throwout bearing, rear main seal
⦁ Flywheel resurfaced and new Flywheel bolts (Toyota)
⦁ Clutch Slave Cylinder and hose (Toyota)
⦁ New Radiator (CSF)
⦁ New Waterpump & gasket (Aisin)
⦁ Thermostat (Toyota) & Housing, Toyota gaskets & hardware
⦁ Upper & Lower Rad and bypass Hoses (Toyota)
⦁ Hose Clamps (Toyota)
⦁ Fan & Fan clutch (Aisin)
⦁ Water Temp sender (OE)
⦁ Alternator rebuilt
⦁ Belts Air Pump and PS Pump (Toyota). New Toyota AC Belt included, though not installed.
⦁ Fuel Pump (Kyosan), OE spacer & gaskets
⦁ Fuel Filter (Toyota); Added second OE fuel filter at tank outlet
⦁ Fuel Hoses (Gates) & Clamps (Toyota)
⦁ New vacuum hoses
⦁ Brake Master Cylinder (Aisin)
⦁ Rear wheel cylinders (OE)
⦁ Brake hoses (Toyota) - Extended front & rear axle hoses.
⦁ Brake Drum Hardware
⦁ Brake Shoes
⦁ Turned Drums
⦁ Front Axle rebuild (OE & Japanese bearings, seals & gaskets)
⦁ Front Brakes Pads & Rotors
⦁ New Distributor Cap & O-ring, rotor, wires & plugs (Toyota)
⦁ New Side Marker lights Toyota
⦁ Hood Shocks by C2 Design
⦁ Rear Liftgate Shocks (Toyota) - Please see pics. I used the wrong brown after I had to replace the mounting stud/ball. My mistake, I was rushing things and got the wrong brown!
⦁ Oil and filter changed (15w-40, Toyota filter)
⦁ Headunit & door speakers replaced by PO
⦁ I've got receipts for parts, all from reputable vendors.
Known Issues:
⦁ Driver's seat bottom torn.
⦁ Windshield needs to be replaced.
⦁ 4 rust holes on windshield frame. Please see pics.
⦁ A hole in the driver's floorboard, probably due to water incursion around windshield. Please see pics.
⦁ AC blowing warm.
⦁ Exhaust pipe has hole.
⦁ Suspension is old.
⦁ Needs paint, eventually
⦁ Cargo area carpet torn, requires replacing.
ASKING PRICE: $18,000
Please let me know if I can answer any questions! Thanks a lot for looking!
