Tailgate Storage
Gardnerville!!!
I wanted to use my tailgate as storage, and while WG mod is great, I wanted to be thrifty, so I made my own.
I found opening marine hatches on ebay for $38 ea, found 12 sf of sound/panel liner $25, bought a piece of .125 alum diamond plate for $5 and misc HW for $15 for a total of $121.00 for both sides.
I cut out the panels of the tailgate and sheared the alum plate to fill the void between the hatches, total time, maybe 30 minutes! Before installing the hatches, I drilled all the holes, vacuumed the debris and wiped the interior area with a good cleaner. Next I applied the liner, pretty easy and stuck really well. Installed the alum panel in the center with a small bead of sealer to stop any rattles and bolted it down nice and secure. Installed the hatches.
The alum panel makes the tailgate very solid and is the area most will stand in, though the hatches are made for boat deck traffic.
I can get my long Eastwing steel ax, Fiskers bow saw, recovery gear, spares, jumper cables and more in easily.
If you need some added storage, this was easy, affordable and works!
I also made another storage in driver 1/4 panel. I bent up some .125 alum and made a tray that I popped riveted to the 2 vertical supports. I have ABS panels, so I cut a hole and added a hinge for access. This tray holds 6 quart bottles, and could be made bigger if wanted. Cost was mu time to make as the alum was left over from the tailgate panel.
Doug
Looks good!
Those hatches could double as a porta-potty, too, in an emergency! :eek:
Dude that is nice!!! Im working on something similar as well.
now that is good.
could you post a link of the hatches on ebay?
Am in the process of renewing my gate now and painting with Monstaliner all over it to match the roof.
thanx
dougbert
Those are T.H. Marine hatches, I believe... Doug, can you post the size, please?
Ordered a couple. Thanks!
A nice, different idea. Looks good.
Top idea mate, being contemplating something like that for a while
Thanks all! I have been very happy with the set up. There is an amazing amount of storage in the tailgate. I have organized it so I have no rattles and the limiting factor in loading is the weight of the tailgate when opening and closing.
On the liner, I lined the exterior skin, the ends, part of the interior skin and the bottom, leaving gaps where the weep holes are located.
Doug
Very nice!
I like the idea. I may end up doing a single 13x30 panel in the center
Dyno
Great idea! I'll have to get me some of those hatches and diamond plate.
Thanks for sharing!
- Randy
I've got quite a bit of sound deadener left over, so I might use that to line the tailgate, that way it'll decrease the sound there and also act as a soft liner:D
:cheers: Spudman
Very clever. Nice clean install. A picture with the doors closed would be appreciated.
