Tail light update from 03 to 06 LED UPGRADE
Australia
found some LED 06 tail lights for $200AUD RRP is usually about $650 so i had to get them.
not getting brake lights or red driving lights in the inner rear lights (the ones in the tailgate)
i am not sure if theres a adapter or harness i can get to make these led's work as the harness has 3 pins in the connector and the light has only 2. i have included a couple images
Welcome to the 'mud, another banana bender joins the ranks :)
There was a thread on LCool (RIP sadly) on updating to LEDs, and yes IIRC it did involve wiring harness.
Here's the wiring diagram for my "old" update series LC100
Here's the wiring diagram for yours
Hopefully that will give you some pointers on what you need, most likely a new wiring harness.
yes i've looked at those diagrams before. its showing the wiring for the outer tail lights which is already working just the inner lights arent working. where in this diagram shows the single brake light bulb
i got the parkers working by moving the pin with the green wire on the lights to the centre pin hole. no brake lights on the tailgate but happy that ive got the parkers on now
