Which mounting system did you go with?
Tall guy means leg lean right in area where the Victory molle mount goes so I can't do that one.
Desert Does It panel on the front seat feet.
I’ll add mine to this…although my floor mats are nowhere near as clean lol
I want to like this, but with it attached to the seat instead of the bolts. When the seat is all the way to the back, it feels the rack is too far forward. And, when my GF drives, the seat hits the metal, so it wouldn't work with a holster.
Yeah I have them and they work really well.Anyone using this?
Land Cruiser Center Console MOLLE Panel | 200 Series Land Cruiser (08-21) - Victory 4x4
Offering quality steel and aluminum goods for Toyota and Lexus 4x4s.www.victory4x4.com
Any issues or concerns with the screws pulling out of the plastic with heavier items mounting to the panel?Yeah I have them and they work really well.
Good to know thanks! Was the plastic panel removal a pain? I am trying to decide if this is worth the effort for more storage/mounting options.I can't speak for @NTV but it was a concern on our GX and I ended up replacing the screws with nuts and washers after the screws slowly started to loosen over time.
If I'm putting any hardware into the....hardware I'm attaching to the plastic trim, it's going to need some load distribution. I added some flat washers and nuts to the back of the seat trim I attached an element fire extinguisher to. The additional load would likely merit fender washers, etc if they could fit behind where you're looking to mount things.Any issues or concerns with the screws pulling out of the plastic with heavier items mounting to the panel?
No issues with mine. I have a molle pouch attached. I could see if you really pull on the plate hard how it could come out but for my use case it has been just fine. On the other side I keep a tourniquet holder and flashlight. Both smaller items little weight.Any issues or concerns with the screws pulling out of the plastic with heavier items mounting to the panel?
On their own no but with items attached potentially depending what you attach to them and where you attach.Does that one prevent the seat from sliding forward all the way?
I forgot to mention I also purchased the door molle panels for the 200 from victory 4x4 for drivers and passenger sides. I have not installed them yet. Thinking to use them for lightweight zippered pouches for small items.On their own no but with items attached potentially depending what you attach to them and where you attach.
