LT1-62 said:Sixty> Even if I mount the spindle on the rear face of the bumper, the most I'll be able to open the right rear door is 90 degrees which is not far enough IMO...
you could build a very simple & economical true double shear hinge with a 1" or metric equivilent hinge. the tire would be able to swing a little over 180* & your ambulance doors would be able to swing almost thier full range if im picturing it correctly.
With a swing up carrier it would be difficult to make it strong without using struts from below that would interfere with the swing of your doors.
swing down would probably be as difficult as swing out but then you have it in the way when you are loading the back of your rig...
Oh yeah... just thought I would let you know your truck looks great. when i paintred mine I was going to go with a similar color but my wife talked me into bright yellow. I'm probably going to go with similar fenders with tubing outside of them to cover the the extra 10" of width from the 1ton axles on my 60.
