I was driving up a steep highway (6%) grade Saturday morning, 50-60 mph, ETC/ pwr button pushed, minimal load. Cold morning (20 deg) heater blowing. Truck starts slowing down, engine is still running fine, but more gas pedal wasn't increasing my speed. No noises I recall when it was slowing down/ loosing power quickly, no jerking or sputtering. So I pulled over and keep the engine running.
Checked the fluid which was at the cold level, which I figured meant it was low since I had driven about 10 miles and the fluid should be warm by then?
Tried to drive a few times but no go, and with the wind chill it wasn't worth trying too much on the side of the interstate. Got the Swamp Donkey (cruiser's nickname for the moose that it is) towed home.
Troubleshooting so far since getting it home:
Checked fluid again once home after the tow, still about the same mark on the stick (low). So I add a little at a time, checking and eventually added a quart. Since I can't drive it to warm it up, I don't want to overfill and the fluid appears to be at the cold level.
The fluid is red and doesn't smell burnt.
Shifted gears while vehicle running = no movement from either drive shaft (I watched underneath while my dad shifted)
Engine rpms change similar to before when shifting gears.
There is no drive power in any gear.
It won't hold in park and grinds when shifting to park while running, but if I ease it forward it goes into park but still doesn't hold the vehicle.
A/T P light was coming on randomly at first but now isn't coming on?
Tried to shift between 4wd Hi and Low but no position makes a difference. The 4wd Low/lock light doesn't come on however.
I am struggling to recall noticing any symptoms of drivetrain issues leading up
Seemed to happen suddenly, maybe I pushed him too hard?
Thoughts are appreciated.
Sorry for the novel...
Jake
Jake
