tnagaway said:can someone kindly explain in Layman terms, the differences,& Pros/Cons between a Suspension lift, and the body lift ?
the latter seems like the less costly of the two, and i would like to give it a try .....
Thxalot ...
brian said:if you're going to lift a truck, that has no lift, go with a suspenion lift first.
there's no good reason to go body lift first.
bandy rooster said:body lift ...raises center of gravity which is a con
chicago said:Im curious...What all is involved in doing an SOA. Looking at it, it would seem that you could just reverse the springs and mounts and youd be pretty much done except for steering components and brake lines. Am I way off base in this assumption?!
Chicago
chicago said:Hey Brian,
Thanks for the tip...This sight AMAZES me with the amount of info on here.
I never thought to go to the other forums....I just figured that I have a 60 series wagon and thats where I needed to be.
HOLY CRAP thats a LOT of info.![]()
Chicago
