Well, I finally saved up enough for the TRD supercharger.
After extensive research here, I was most concerned about being able to handle the crankshaft bolt.
It turns out that was not as difficult as I thought. I was hesitant to use the starter bump method so I made my own SST.
it worked like a charm.
Unfortunately I didn't have enough length to connect the TPS and IAC plugs and had to lengthen the harness. This was the single most tedious part of the install. All wires were soldered and shrink tubed about 8" over stock.
The only othe problem encountered was getting the 90 degree elbow installed between the plenum and the intake runner. I had to fight with the hoses for about 15 minutes before it finally fit.
This shot shows everything except the lengthened IAC and TPS harness.
I won't go into much more detail since everything has been covered here to death.
I will add that the seat of the pants perception was not as dramatic as I had expected. It sure does pull through the mid-range better than before. At the upper rpm's (3250-4800) there sure is a lot of commotion going on! There is a distinct whine from the front and the exhaust whistle people complain about stock becomes much more pronounced (even with my Borla exhaust.)
I only have 150 miles on it so far, I will report back after some more miles add up.
I'm also waiting to compare to my girlfriend's GX470 before passing final judgement.
So far, the jury is still out if the power is worth the cost and effort.
Boyd
Boyd
